Moritaka upgrade and spa treatment
Discussion in 'The Kitchen Knife' started by Pennman88, Jul 10, 2018.
  1. Pennman88
    Got this 270mm Moritaka kiritsuki from
    Cheflarge and it was a beast. It is AS clad in iron (I have my doubts) was about .08” thick 5mm above the edge and really convex. See cheflarge’s photo of the choil in the second photo. I thinned it to .012” at 5mm above the edge and got the edge .004-.006”. See the choil chit in the third photo. I reprofiled the blade down to 250mm and raised the edge. After a ferric dip, you can see how close the cladding comes to the edge in some places. I have a feeling that the cladding was actually on the edge on the original configuration. And the cladding was non-reactive to the ferric so I think it may be stainless. Time will tell. Right now this blade is an incredible laser and falls through food like a scalpel.
    69774821-811F-4DB1-A123-3B2F54ABAD4C.jpeg 0E424FA7-A431-4037-B931-007906B8CCCE.jpeg
  3. Cladding going up to the edge makes it simply impossible to take or hold any edge.
  4. Rick
    Agreed, but only if there is no core steel exposed.
  5. Pennman88
    If you look between 2-4 cm form the heel on both sides of the blade, you can see the cladding is so close to the edge on one side, within 2mm. I ground the blade back a few mm in this area. So I’m suspicious that the cladding was actually on the edge and the core was rather wonky in its centering between the cladding.
