Knife Sharpening
Discussion in 'Sharpening forum' started by kentos, Feb 18, 2014.
  1. kentos
    kentos Founding Member
    After many years of hand sharpening my kitchen knives with varying degrees of success, I finally bought an edge pro to try and get all my knives on the same page. Prior to this I noticed all my knives had very wide bevels due to my haphazard honing angles. So today I am slowly trying to bring the bevels back. Any suggestions on the coarsest stone I can get for the EP?
    Also, what does everyone else use on their collection?
  2. Argonaut
    Lapping film.;)
  3. kentos
  4. smith
    smith Founding Member
  5. kentos
    Thanks! I have a glass plate I was going to use for film but never thought of using it for coarse wet/dry. One tracked mind I guess. If not I'll get that plate.
  6. Bill Farrell
    If you want coarse, there are diamond stones for the EP. I've used them and they work well to bring a really dull knife back into some sort of shape that will allow the finer stones to be used.
  7. Baker_Rat
    Baker_Rat Founding Member
    So when finishing the edge on a kitchen knife, about what grit is most common to use?
  8. turbo
    turbo Founding Member
    Probably 5-6k. On butcher knives I like 2-3k but am silly and will sometimes finish on an 800 and then strop. Single bevels go much higher. I like the lowest I can get away with it gives a more well rounded "forgiving" edge in a pro kitchen.
  9. kentos
    Some guys stop at 220, some go to 12,000 and beyond. As a novice Edgepro user I stop at 600, but I have a 1000 stone.
  10. John Fout
    an 8k edge is so smooth... I go 8k on my japanese geometries, 1k possibly 4k on my Sabs- depends on how I'm feeling when I'm sharpening and what I know I will be using them for in the next month or so.
    I can get 4-6 weeks of heavy use on a 8k finish on my work knives. When I rotate I, sadly, break out the stones one every three months and usually sharpen before I need to just because I like to.
  11. Baker_Rat
    Cool... so with the majority of my cutting being mostly chicken breasts into cubes, and some chopping and dicing of veggies, the 220/1k stone with some stropping could easily be enough, then.
  12. MotoMike
    Has anyone tried the Chinese sharpeners on Ebay that are blatent knock offs of the Edge Pro? The Apex clone goes for around $25 and the bigger one with the suction stand goes for around $35 to $40. I see that the clamp is simpler and does not have the ramp, but the design seems serviceable.
  13. Bill Farrell
    The EdgePro clones are a little less robust than the original, but they work fine.
  14. MotoMike
    Thanks Bill
  15. Paradox
    Paradox Founding Member
    The stones that come with the EP clones really suck though. Even if you just get stones from EP you are making a huge upgrade to the EdgeFaux set. Also I think Bill is understating the issue when he says they are a "little less robust". The one I got to compare them to the original was WAY less robust. In the first two weeks I had mine I had to do a JB weld repair to a break that made the machine unusable.
    The rear bracket on the stone holder broke, it was a catastrophic failure to say the least.
  16. erikz
    erikz Founding Member
    Planning of selling my EP in a week or so. Ive got 5 stones in the way and making the plunge into freehanding.
    I own an EP with a full set of EP and Chosera stones. PM me when interested and we can work something out maybe.
  17. MotoMike
    ordered and received one of the Apex clones a couple days ago. sharpened my Kai Nakiri and a Gerber utility knife on it. I can see that it is an acquired skill but the scheme seems to be an improvement over my beloved venerable Lansky. I don't find the included stones to be terrible. I will look at some Edge Pro stones, particularly a coarse one to get the initial bevel right and a more fine one to finish the edge.
    Paradox, I can see that block you broke is a weak point in the faux versions. I see in the instructions they warn against tightening the stone too much. I found that it really did not take much tension to hold the stones firmly. I do note that if you are doing a knife that you don't want scarred up, you need to cover the portion that touches the blade table with some tape prior to sharpening. Otherwise moving it back and forth will leave striations on the blade over its full length parallel to the blade edge.
    One is faced with these dilemmas. The fake EPs are 1/10 the cost when considering that you get 4 stones with them. (180, 400, 800 and 1500 I think). They are truly blatant copies of the EP design and one must consider that much research and development went into the designs, but is the Faux version 10 times worse than the original. I'd say no. It is perfectly serviceable and with the purchase of a few better stones you are still way ahead.
  18. MotoMike
    in some pics I've seen a magnifying loop. what power is usefull? I have a 60 to 100 power, but it is too finicky to look at the blade edge. My 2 power binocular magnifier is more useful.
  19. daveb
  20. MotoMike
    Thanks Dave
